SMaeller
I recently took a motor from a 1990 SHO that passed smog in May 2009 and put it in my 1992 SHO (which passed smog less than 1000 miles ago, before I spun a bearing). Along with the motor I used the year old O2 sensors that were in the '90 and my relatively new (less than 1000 miles) cats from my 1992. The car runs great except it fails smog across the board (CA emissions test). Initially it failed as a gross polluter across the board and I found a temp sensor that I had not connected (on the heater hose tube). After re-connecting the temp sensor it's no longer a gross polluter, but just barely and still on every measurement. You can stand behind the car and smell that it is running very rich. Note: oil, filter, plugs and wires are all new and the K&N air filter is clean.
So I took it to a well recommended local mechanic and he checked every connection, looked for codes, checked fuel pressure and nothing is wrong except it runs very rich. I'm stumped and more importantly, the mechanic is stumped too.
Has anyone ever seen this in a Gen 1 or 2 SHO? What would cause it to run rich and yet give no codes or any other indication of failure?
