1991 Rear Brake Calipers Screw in Piston
shotaurus
so. cal.
OK I did the rear brakes on my SHO , the left side was fairly easy but the right side caliper piston does not seem to be going in all the way , the emergency brake is off , there is almost enought clearance for the brakes to slip on the rotor , but the piston does not seem to be going in all the way , factory Ford rotors , factory Ford rear brakes , thanks in advance for your help.
shotaurus
so. cal.
I did a search and read some other info about rear brake calipers and they say loosen the bleeder screw so thanks again for all your help.
ribeye2065
