1990 sho dirt track car wiring
Cert88
Pa
I'm making my sho into a dirt track racecar.
I thought the only thing I needed to keep wired behind the firewall was the fuel pump. But apparently not, engine cranks but won't start. Fuel pump works. I bypassed ignition, so it's just a switch, no key.
What am I missing? Any components need to be hooked back up behind firewall?
Any grounds, besides fuel pump?
I'm about ready to remove complete harness and wire the minimum.
offroadsho has a thread here that tells you exactly what needs to be wired to make the engine run. read that carefully.
Cert88
Pa
I seen that, but that was for a 3.2, mines a 3.0. Any difference for minimum wiring?
Off Road SHO
Moderator
I really need to delve into the 3.0 wiring diagrams and write up a How To for it also.
Tom
Cert88
Pa
Is it pretty close to the 3.2?
So I can get started with it, and modify it slightly once I figure it out completely.
I updated Tom's thread with what I found in the 1994 wiring manual.
poffffd
