1990 3.0 MTX backfires
Bruce M
SHOBAM
Kingston, MA
Sometimes on startup (cold start up but can happen hot) I get either misfires or backfires. These are not loud and might be mised if your not expecting it. If I shut the engine down and start it up again they often go away. Scanner says CID. so its pointing to the Cam posistion sensor. Will these motors even run with a bad CPS or a faulty CPS? Has anyone had these symptoms before and is tyhe CPS the likly susspect?
Cocoa,Florida
if thats what your scanner is saying,id say the CID is a good bet.
id go ahead and reset the ecu and wait for the problem to occor again then check the codes once more.
thatSHOguy101
