kylix.rd
Does anyone know whether or not a multi-function switch/turn signal switch from 1990-up will work with an '89? From what I've seen they were redesigned in 1990 WRT how the wiper switch works. For '90-up you rotate clockwise through intermittent to lo then hi. For pre-90 you rotate clockwise for lo then to hi, and counter-clockwise for intermittent. If the connectors, pinouts and electrical sematics are the same, I don't see why it wouldn't work. However if any of those are off I can understand why it won't work. I'm just having a hard time locating an exact replacement and the dealer wants $230! I can find 1990-up replacements all over eBay and similar sites... Just no pre-'90 versions, used or otherwise.
FWIW, I think the '90-up design is far more intuitive and have always thought the '86-'89 wiper switch design was silly. I'd rather replace it with a '90-up version if it will work.
I'll probably have to start calling the local salvage yards to see if they have anything earlier than '90.
kylix.rd
kylix.rd
