18" Wheels?
Primate
Altamonte Springs, FL
I was reading on the V8sho website in the section about wheel size alternatives and they were saying that 18's significantly hurt ride quallity. Anyone have anything to say about this from personal exprience?
Nate
Brett
SHOs before HOs
Minnesnowta
Any larger rim is going to hurt your ride. You have to find a medium. Ofcourse a larger, lighter wheel with harder, stickier rubber is going to hurt your ride. You could counter act this with less stiff struts but then your sacrificing performance. If you want good looks and better performance, you'll have to sacrifice some luxeries!
MetalheadSHO
Wichita, Kansas
You're in luck :evilgrin:
I was actually in a 98 SHO with 18's and it makes the ride alot more rough. Not to mention it adds extra weight. I wouldnt go any bigger than a 17".
Primate
This was the direct wording...
"SHO Shop reports very poor ride quality without improved performance when they tried 18" Rims, this is a cosmetic only mod."
98TRSHO
kalamazoo
How bad did it look?? I'm not think of doing it but i would like to get alittle bigger the then 16's that I have now.
wuzzzer
MN Moderator
St Cloud, Minnesota
Don't go with 18s if you're not lowered. Even my 17s made my car look like it had a huge wheel gap before I had it lowered.
One of the big car mags did a test a while back with a Honda and they started out with the factory 15" wheel and tested a 16, 17 and 18" wheel as far as handling, skidpad, etc. They found that the 17" wheel/tire combo consistently performed the best.
NebraskaSHO
Harumph!
Omaha
Mark just where are you supposed to find lowering springs?
98TRSHO
kalamazoo
I can get lowering springs for my V8 here at Lane aoutomotive for less the $300
2 4shofast
Ogden Utah
I couldnt agree more with Mark, you will not like the result if you put 18's on your car without changing out the springs.
hoboprodigy-
SMOKE
Troy, MI
I downgraded from 18's to 17's in hopes that a little more sidewall would help ride comfort on these michigan minefields.. it does.
I run a 225/50/17 and the handling is supurb
edit: those are the 17's in my sig btw.. i think anything bigger is pushing it for a taurus..
wuzzzer
MN Moderator
St Cloud, Minnesota
Some of the Roush springs turn up from time to time on eBay. Also, the procedure of lowering the front strut tab as outlined on www.v8sho.com will help if no springs are available.
2 4shofast
Ogden Utah
Some people dont recommend the eibachs because they are made for the SLO's. I ride quality didnt change that much and I couldnt imagaine rolling around wiht 18's and not lowered....here are a few pics of mine on 18's with eibachs.
MVC 445F
337561 203 full
GenRear005
SuperHO
Mental Patient
St. Joe, MI
dammit, dude, stop posting pics of your car....every time you do, I gotta work on my wife's...:biggrin:
that thing is teh sexness.....:dribble:
NebraskaSHO
Harumph!
Omaha
Yea I found some Rousch's on eBay but Chrixtopher bought them from under me!!!
crixtopher
Richmond, VA
whats up Paul, I just so happened to have more money than you did at the time thats all. sad thing is they are still not on my SHO yet. won't bore you with details. I still plan on using them once all the stars are aligned, but if for some reason I end up ditching them I will PM you first :thumb:
Revere sho
Revere MA.
what do those rousch wheels look like? does anywho have a pic?
also so how do u guys put in that Originally posted by quotes?
NebraskaSHO
Harumph!
Omaha
No... rousch springs.
It's awesome that someone on the forum here got them. I would be in the same boat and wouldn't get them installed forever either. :) I was only kidding about you stealing them from under me. I never have any money so it wouldn't have mattered!
revere sho, hit the quote button down at the bottom. You then can edit out just how much you want to quote in the new post.
