SHO SPD
SHO member #480
Is there a retrofit kit for our cars? Does the accumulator need to be changed in a Ford? My A/C needs a lot of work, probably not even worth doing.
jelloslug said:Another tip: Dont get cheap when you buy your R 134a. I have have 2 cans of "no name brand" R 134a rupture and spray liquid refrigerant out. I was lucky the first time and I started wearing welding gloves when handeling anything except ID or DuDont brand R 134a.
HighSpeed said:What I find odd about refrigerant handling is, to handle most refrigerants, you need to be certified to handle it. But you can buy R134a off the shelf from Wal-Mart. Anyone notice that?
You need to be EPA 609 Certified. Its not hard to get certified, only a 50 question test. I got a 92% on mine. rangerj said:R-12 refrigerant is now at about $225 to $250 per pound (16 ozs).
ohioshodude said:hummmm really.... i have about 4 can's of r12 in the garage! i could make a killing if only it was legal to sell it.![]()
i got a question you guys might be able to help me with, i've got that 94 engine in the garage and i was thinking of just putting the A/C compressor in the 91. it has all new lines, including the dryer and acumulator. should i use the old pump or use the newer 94 pump?
