MeeSHO
SHO Owner
Well with 120k on the clock the transmission is finally going in for a rebuild. As far as I know it has never been worked on and it is def. the original transmission. While I have the wife talked into letting me spend some money on the SHO, I want to replace the wear items. My list of to-do's includes coolant flush, PS fluid replace, fuel filter replace, endlinks, strut mounts, subframe bushings, and swaybar bushings. Eventually some new SARC struts, but not until all the bushings are replaced. I will be adding an aux. trans. cooler as well. I had my cams welded at 80k and had the 100k maintenance done at that point. So, is there anything crucial that I should do at this point? There are other "upgrades" planned for later, but right now I want to get all the worn out stuff fixed. She rides a little rough at this point and I just want to smooth her back out...
Also where would you recommend getting the right parts?
