38SHO
#1 Oil Abuser
so whats the scoop on the 11.6 rear upgrade sho source offers?
I tried to do some searching but I only come up with front brake stuff
the kit includes a new bracket, and what hardware? just the bracket to hub bolts?
also see it has a hubcentric spacer... I take it the front is different then the rear and requires this.... even for a 93?
also maybe a stupid question, but does it fit a slicer? if it does, does it require a spacer?
requires 89-92 calipers/brackets....... does that include any Taurus with rear discs of those years? this helps with my junkyard searching..... Also I assume it uses the same applications pad?
any thoughts owners of this mod have about this brake setup? I will probably pair it up with a 11.6 front setup for now......
thx
thx
