02 Audi A6 Quattro maf questions
Xavier36
Raleigh NC
I have an 02 Audi A6 Quattro 4.2 my issue is have a new maf and new connector unfortunately I unplug the maf and car still runs, while driving n maf plugged it's crappy unplugged it's excellent any input on my issue with my maf
NoSlo
SHO Owner
Portland, OR
New doesn't always mean that it is good. Kind of like new members that "introduce themselves" in a Ford Taurus forum with Audi questions.
It it were my car I would look at a good working oem unit or the connector is bad. Could be something else in the wiring or computer but I would not go there until I was sure about the MAF and connector. Usually if it runs better on default without the sensor, the sensor is faulty.
Xavier36
Raleigh NC
I reset ecm yesterday it ran good for an hour then a wire came a loose and it started acting up again going to tackle it again today
Wiring issues will make you chase your tail. the hardest part is finding it. if you know where it is then your way ahead.
NoSlo
SHO Owner
Portland, OR
What was the symptom that made one replace the MAF and its connector in the first place? If all that work didn't change the symptom, then you might just be barking up the wrong creek without a paddle.
Xavier36
Raleigh NC
It's jerking n stalling lost of power especially when going up hill
Echoing above. You should have stored computer codes. Those should always be 1st check unless you have an obvious issue like a spark plug blew out of the head or broken wire connections
Xavier36
Raleigh NC
It's bucking n loosing power especially uphill
Xavier36
Raleigh NC
I was told today it could be grounding issue
Could be grounding issue. Also some aftermarket parts are suspect. I never trusted aftermarket MAFs and always (after I got a bad aftermarket one) got a used factory replacement. Search what Audi models use the same MAF as the one in your car and look around for a used replacement. That's my best guess without getting more information or getting my hands on it. I guess I would also look at the connector replacement and the wiring there
There are local salvage yards and also used auto part search engines on the internet that make locating what you want very easy. also ebay
Xavier36
Raleigh NC
It's Bosch
Both the 2.7SC and the 4.0 apparently use a MAF sensor, and I ASSUME :) they are not interchangeable, but I could be 200% wrong on that.
bmytych
