92 MTX SHO - Mustang Dyno (Now with Video)
SHOspazz92
Banned
Triad Area, North Carolina.
219 FWHP.
177 FWTQ.
http://s132.photobucket.com/albums/q29/kellen17/?action=view&current=MOV02357.flv
All this on a Mustang Dyno.
3.0L engine with fresh rod and main bearings (July 2008)
TwEECer RT
SHONut +20 cams
SHO Shop BBB
PNP Intake Manifold.
75mm Pro-M MAF
3.2 injectors
3.2 oil pump
custom 2-1/2" stainless exhaust system
Magnaflow stainless resonator
Magnaflow stainless muffler
Accel plug wires
Swain Tech coated exhaust manifolds
FPS stainless catless Y-pipe
Walboro 155 LPH pump.
Deleted A/C System.
My First two numbers were in the 190/160 Range as they were having trouble calibrating there dyno for my car - The car had to be Dynoed with the Dyno in AWD mode (So my SHO appeared to be AWD at times ;) ) and a few other things were kind of screwy with the Dyno, But eventually they were able to get those numbers. Unfortunently, Because it was a Dyno Day they had another car on the Dyno before I finished parking, So when I went back in to get my sheet they already had myself stuff out of there system. I'll get the car on another Dyno again soon to get some solid numbers.
Video's to come soon.
-Sam
BlackonBlack89
burlington county,NJ
cool to see u took into to the dyno. I wonder wat they had trouble with? Weird they had trouble with my car too. The first TQ was only 152 :oogle:
Go to the real dyno..............1/4 dyno ::frantic:
Edit* wasn't this car dyno'd before. It was at 260(chp) something IIRC.
Brett
SHOs before HOs
Minnesnowta
OMG great numbers at what RPM does the vtac kick in 9.5k?
the 200 torque number was from a 3.2. Also mustang dyno vs. dynojet (im guessing) EDIT: looks like i was beat to it.
Boo for selling the zex kit... Just throwing that out there. :sun:
Great numbers sam, Interested to see what kind of numbers it'll make on a dynojet.
I dunno how i'd feel about someone who has so much trouble setting up their own dyno, or the numbers that came from it.
NEW EDIT: you start playing with the tweecer yet sam?
SHOspazz92
Banned
No, I'm having trouble getting Calcon to work. Caledit reads the Tweecer but for whatever reason I can't get Calcon to, I'm looking in to it.
-Sam
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
Sam, try payloading the tweecer to datalog.
And, it is highly dyno-calibration dependant with a Mustang. My 92 made 204hp/208tq on a mustang dyno (stock 3.0)... 194/188 on a Dynojet.
Might as well go find a dynojet, they're more likely to spit out generic, repeatable, somewhat-roundabout-maybe accurate numbers.
1995SHO9
FLEES ARE COMIN
Carlisle PA
-Sam
TWEECER SUCKS TO TUNE WITH !!!!!!!!!!!!!!!!!!
The Apexi was so much easier, I wish I would have stuck with it...
Anyways, I had a hard time with running it on window's vista, which op system do you have?
1995SHO9
FLEES ARE COMIN
Carlisle PA
Hmm, I'm not sure, but I know under the help section, it will tell you how to make it work with various op systems.
~Johnathon~
AutoSHO
No SHO = Mo $$$
Fort Collins, CO
If you take the time to learn how to use the tweecer, it works better than any other solution out there that keeps the stock computer.
Of course the Apexi is easier, it's made so that all the Honda/Acura owners out there can use it.
Toolman
Boost it!
Grand Lake, Oklahoma, USA
Wasn't one blown engine enough for you?
Back on topic, go to different dyno Sam. Dynojets are way more consistent from what I have seen. My car has seen 4 different dyno, maybe 6-7 different times, and the numbers were always very consistent. I think from one dyno to another here in Tulsa (with different days, different operators), the numbers were within 0.5%
yamahaSHO
E85 whore
Arkansas
219 FWHP.
177 FWTQ.
TwEECer RT
SHONut +20 cams
SHO Shop BBB
75mm Pro-M MAF
3.2 injectors
3.2 oil pump
Accel plug wires
Deleted A/C System.
-Sam
Those are pretty similar to my old numbers on a DynoJet. I'm not sure how your tune is, but we woke my car up after tuning (wasn't tuned on the dyno). Keep up the good work FOKKER! You can always find my number in the global if you're needing some tuning help.
It's actually quite easy... Having a clear understanding of how an engine works, what causes x in an engine and how the computer is doing things makes this st00pid simple.
As for as your OS... I don't think it was every really meant to be on Vista. I keep XP on my laptops just for this.
You mean it's gotta be on a level for the masses of teenagers out there with their mad-tite Honda's :snap:?
:hdance:
I have only ever used a DynoJet because of this.
