RJ-92
Jason is right guys. Going with a larger MAF on even a bolt-on car isn't going to get you any HP. You need to be running some serious NA mods (3.2 cams+) to even getting close to maxing the stock MAF, probably in the 250WHp range. If ia near to stock or bolt-on SHO does run better with a different MAF that would be chalked up to dumb luck and idocyncracies in the voltage output variance between a particular unit vs. another.
