Well I was thinking that "project turbo granny sedan" wasn't pulling like she shoudl. So after taliking to several people it sounds like the internal wastegate its getting stuck half open. So tommorow I'm going to shut it totally and up the boost around 3-5 psi so hopefully she will pull like her old self again.
I'm just looking for the power I used to have when she would put 2nd gear up in a blaze of smoke and slam off of the rev limiter before you would have the time to let up off of the throttle. So I will keep you all posted how this goes.
Because as of now it is taking forever to spool the wastegate, whick leads us to belive it is jamed half way open...
STAY TUNED FOR A DYNO UPDATE, when we start pushing the limits of the SHO motor with exclllant tuning!!!!!!!!!
Wired shut wastegate....
yeah then he can blaze the tires in all gears
A BOV prevents too much forced air from slamming the TB and surging the compressor. A wastegate reroutes exhaust to keep the exhaust turbine from overspinning and self destructing/creating too much boost.Spool a wastegate? You spool the turbo not the wastegate, the wastegate just opens when it hits a certain psi to prevent too much forced air from hitting the throttle body. What exactly are you asking here?
LOL, good luck:corn:it sounds like the internal wastegate its getting stuck half open. So tommorow I'm going to shut it totally and up the boost around 3-5 psi so hopefully she will pull like her old self again.
Oh he'll up the boost more than 3-5 PSI if he shuts the wastegateLOL, good luck:corn:
When the wastegate is open, your TB should be open (generally WOT).
Actually, the wastegate regulates the amount of exhaust that goes through the exhaust turbine (which in turn, effects how fast the compressor side spins limiting boost the boost created).I should have been clearer. The wastegate regulates the amount of forced air going into the tb/intake. Yes the BOV prevents too much forced air from slamming the tb when its closed but only when its closed. I'm sure you know what you're talking about I just made a confusing post.
