wuzzzer
MN Moderator
I started driving the SHO about a week ago after storing it for several months over the summer. The brakes initially seemed ok. Each day the pedal has been getting softer and softer until on Saturday it would grab for the first inch of pedal pressure and then it had a few inches of nothing and then it finally would grab more with the pedal pushed almost all of the way down.
I remember reading a while back that its good to use the car's emergency brake now and then if you start getting a soft pedal feel. On Saturday after starting the car I pushed the e-brake down and left it there for a few seconds. I popped it back out and then on the way home the e-brake light flickered on and then back off. I pulled over and pushed the e-brake in and popped it out again. A little while later the light came back on and has been on ever since.
Today on the way to work there was absolutely no grab to the brakes until I pretty much had the pedal pressed to the floor. On the way home tonight it seemed to get worse.
When I pulled into my garage I could see that something had been leaking near the front driver's side wheel. Looking at my driveway I could see something had leaked in a few places there also.
I will be calling a mechanic tomorrow to see if I can get my car in and I will not be driving it at all other than to the mechanic who is only about 2 miles from my house.
Is there anything specific I should tell them to look at? Could it be anything other than the brake lines?
I probably need new front brakes also so I guess I'll have them do that as well.
Thanks all!
Thanks all!
