All cams welded Still engine tick on idle?
eli terry
Davenport, Ia
Does not seem to be injectors? Can't locate the tick but seems to be in the front head towards the water pump side. Any body have any insight? Could it be valve lash?
Thanks in advance
ThatShoGuy
michigan
is your consistent?
i get a bit of a tick when i start the car up soon as the oil light go's out its pretty much gone....
I have an exhaust leak that ticks for a 30 seconds or so at cold engine startup.
eli terry
Davenport, Ia
Just Must be a Gen 3 SHO Characteristic!
Just Must be a Gen 3 SHO Characteristic! I had the valve cover off checked shims and all are ok. Everything looks in order and checks out? Chain tension is tight. Can't find any problems?
Izzmo
SHO Enthusiast
Kansas City, KS
Hmm, I know it's already been said, but mine ticked (severly) before I had mine welded. Once welded, all gone.
