Pinch Joint on Rear Spindle
RiceeatingSHO
Travis R
Alabama
How do I get this thing back together enough to thread the bolt in? I have hammered on it with and without strut in place but just can't get it close enough. No, I don't have a torch.
I might have used a vise grips. I don't recall it being that difficult. The pinch bolt should have a point on it(just so you can be sure you have the right one).
RiceeatingSHO
Travis R
Alabama
I'll go try that, and it is the pointed bolt. it almost threads but just not quite. Well, it tries to catch the first thread but hops off....
Storm-Chaser
Shit Louis
With the exception of rust build-up inside the threads, the bolt should readily/easily begin threading back into the spindle. *The* only reasons other than rust for the bolt not aligning, is if the two-halves were spread too far apart, the spindle is bad/damaged, or the pinch-bolt is bent (which shouldn't be reused in the first place).
If you have access to a tap-and-die set, run a tap backward through the threaded portion of the spindle. If the bolt won't then start, I would suggest getting another spindle.
:burnout:
RiceeatingSHO
Travis R
Alabama
Putting it all back together I realize that I'm missing one of the rear tension strut arm bushings. Can I buy just one of those?
