Fuel pump probelm - code 95
mrgrim333
Colorado - Northern
Ok, more problems for me lol.
Anyways, I just put a new starter in, because my other one was making the wwwwwwrrrrrrrrrrrr... sound.
So I popped the new starter in, makes some good sounds... but now my sho won't start.
KOEO test time. Code 95:
95 (O) Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
Did I fudge up the wiring? :(
2manyhobbies
Rockford, Michigan
Always check the inertia switch first. See if you have power in and out with the key on. With the key off you should have no power at all. Next check the pink/black wire at the computer, that is the wire that sends power to the pump. If all that checks out, check and make sure the ground is good by the pump. My 91 just died Sunday, no fuel pump. I replaced the pump then it still wouldn't start, after checking it all out, I found no signal from the computer. I tapped on the computer and it started. I am going to replace the computer anyway.
mrgrim333
Colorado - Northern
Where's the computer located?
