Will it work?
TopGunnYFZ
Livonia, MI
Hey guys I've got a bad wheel bearing on my Gen 1 and I was forced to drive it with it like that while my other car was down for a 60k. I was wondering if i could just swap over a whole knuckle assembly from another gen 1 slo instead of messing with the hub to find out the knuckle is messed up from me driving on a messed up bearing.
So Question is will a Gen 1 SLO knuckle work on my Gen 1 SHO?
Your 90 have antilocks? if not, you can use a SLO knuckle all day long. If it DOES have antilocks, then you will ahve a hard time finding a SLO knuckle with antilocks...
but....
You can toss the SLO....non-antilock...knuckle in there while you get the wheel bearing replaced on the SHO knuckle....
icemaneric
Cen. Cal (Modesto area)
That I knew of, 89 was the only year that ABS was not available in the SHO. I also think it has a knuckle that was used for that year only. 1990- 1993 SHO's used the same knuckle.
If you car is a 90, find your self a 90-93 Taurus any model line L, GL, LX, SHO. Make sure it has ABS, and use that knuckle.
Deja vu, a posting similar to this one was posted yesterday.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
don't forget to check out Sables too, also the wagons of each model have the exact same front knuckle as the sedans
