Lookin for a old SHO owner! White 94
ShoBall93
Westfield, Mass
Hey guys.. I just picked up a 94 ATX sho off craigslist for cheap.. It had the NESHOC stickers on the rear 1/4 windows... I was wondering if it was any of you guy's car.. Its a 94 white, grey full leather, roof, with 116k ... Looked bone stock other than the lower airbox had small holes drilled into it.. Its coming with TONS of maintence records and things really nice.. Truck/spoiler needs paint cuz of ford quality paint but other than that its really clean!
Any of you guys?
heres a pic
01020201160501030520080714bebccef3f
010211011602010310200807140af7ebd80
ShoBall93
Westfield, Mass
HAHA thanks... I miss my old 93.. soo I cant wait! just gotta fix a electrical problem it has... seems 1/2 the time the alt is not charging the system and then all of a sudden it charges.. not shure but I feel it must be the regulator either way its worth sending it to the shop its soooo clean
GaryH
Burrillville RI
i seen that one on craigslist and was thinking about it but didnt feel like dealing with the elctrical system. good luck with it. it looks clean!!:thumb:
ShoBall93
Westfield, Mass
It is rather clean.. the trunk and rear 1/4s need paint and a tiny bit of body work.. underside is nice no rot at all! soo its worth saving! I love these cars
ShoBall93
Westfield, Mass
So what I have gathered from the forum is check the plugs on the alt and send the alt to a electrical guy who rebuilds them and have him test it... also it could be the voltage regulator
Kens1992mtxSHO
The Commonwealth
Electrical gremlins are the worst.
If it's an alternator you suspect I would take the alternator and battery to have them tested at the same time.
ShoBall93
Westfield, Mass
it was the regulator in the alt.. installed a new one.. everythings fine :) The oil leak turned out to be a oil pressure switch next to the trans.. it was leakin down and lookin like a rear main seal.. I dident notice it till we got the trans out... soo while i was down there did new rod bearings, rear main seal and oil pan gasket. Also replaced some rotted brake lines and near serp belt.. Car runs great.. my subframe has a nice rot hole in it right near the rear pass side mount.. anyone have a atx subframe? in decent shape?also subframe bushings
shobroooo
