Would this fuel screen be ok to use?
1993MTXSHO
Its a Taurus...
Jersey
Well I decided while my pump was out I would replace the fuel screen. So I ordered a new one, and this is the one the parts place gave me (the white one). I am worried that the hole is in a different location then the original and may not feed the pump right. It will now sit in a different location in the tank and I am also wondering if it will even go back into the tank because of its different location. Before installing it and losing he money I paid for it if i can't use it, I figured id ask to see what you guys thought on this.:)
shoshirtsandhat
PA
I Replaced My Fuel Strainer Last Week And It Was Exactly Like Your New White Strainer , Works Just Fine .... Change Your Fuel Filter Also While The Car Is In The Air..rear Pass Door Area /2 Plastic Clips To Remove From The Fuel Line And It Is Basically Out, Make Sure The (fuel Filter Flow Arrow) Is Going In The Rite Direction When Installing It.
Joe
1993MTXSHO
Its a Taurus...
Jersey
Joe
Already on it, and believe me, EVERYTHING on my car is getting changed, its been in the air for almost 2 years, its getting a resto pretty much;)
shobroooo
