Should the steel insert on a fidanza sit above the aluminum around it? On mine it appears to be on flush with the aluminum around it. I’ve heard the recommendations to get the flywheel machined before install because the factory doesn't always do a great job. If the insert is flush with the alumin around it, can the insert still be machined? What exactly should I tell the machinist to do?
