pictures from Sunday's Meet
Inkertinker
Well-Known Member
Charlack, MO
OK, I was not yet home when James and Steve arrived in 2 of James's SHOs
DSC00386 1
I already had one of James's Loan-a-SHOs
DSC00387 1
Very soon after Goalieman arrived sporting some new killer wheels
SweetridewithnewShoes
James took a look at the "I Got Rust Mobile"
GotRust
A few days before I went to "Pick & Pull" and got the donor metal for $34.
James did some measuring and some test cuts to find the best "slice" as it were
Sizingthenewmetal
Plan "A" was to cut a larger piece and use a flanging tool to make the repair but the glue and lack of space called for a butt weld so James went to plan "B"
Cuttingouttheold
Steve removed the old metal (I'm not really sure what he was thinking here)
Steveremovestherustypart
Curt arrived earlier and I began my part, Curt needed a broken sway bar replaced, Aluminum sub-frame bushings installed, sway bar links, other front motor mount, and a replacement left strut.
OthergoingsOn
Goalieman worked on some engine detail
DSC00431
James continued to work on my car.....
Minordetails
James "tacked the new piece in place"
DSC00482
After grinding the welds to test the fit and smoothness, James completed the welding
Checkingthefit2
A thin coat of "plastic" was applied
Thefirstcoat
Shaped
Shaping
James was just about done while I got some help finishing Curt's car...
Puttingtobacktogether
Then James primed his work
PrimerCoat
Many thanks for those who SHO'ed up. Thanks for the food, drink, cooking and labor. Everyone was helping out, it was a really good time..:thumb:
Got Rust??? Not any more!!! Thanks to all...:salute:
Dave
SinisterSHO
Rust free
630, IL
I have this problem that if I have any alcohol in my system. I'm making that face if you take a picture of me.
Also, I'm going to have to ask you to edit or remove that picture due to me holding a bud lite.
ManySHOs
South Jersey
Wow, no gloves or eye protection when grinding or welding! :oogle:
Awesome work, great pictures. That roof repair looks great!
Ian
Storm-Chaser
Shit Louis
Address? I tried finding it this morning, and apparently no one in STL knows the difference between Vavoline oil change and [insert every other name here] oil quick-change in St. Louis . . . .
I wish people would just say they don't know, versus trying to make-up ********. :rant:
There was only one listed in the yellow pages at 2200 Capital Drive, with a (636) number.
Yes, I have a receipt.
edit - I won't be able to get it to you until this evening (ie. after 7PM unless we get a rain delulge) - PM me your home address if you want me to bring it by there . . . .
:burnout:
kikkinasphalt
Wrrrrrrrr
Missouri
i can meet you at James if he is ok with that....
its on my way home.. im not off till 7 so that works for me
Storm-Chaser
Shit Louis
The car is being sprayed with the windshield, backglass, and channel run moldings removed . . . right ?
crystizel
