TaurusPimpin
I have just converted my '97 Vulcan-powered Taurus to a manual using the MTX-IV from a '93 SHO (I know, it's not a real SHO!). I got it running on Tuesday, after months of planning, and two weeks under the car. Now I'm having a lot of difficulty shifting.
From a stop, I have no problem starting in first or reverse. Once the car is moving, however, I will depress the clutch pedal and push the shifter to the desired position, as far as it will go. As I release the clutch pedal, the tranny will grind, and I will quickly press the clutch pedal again, and the tranny will engage the gear. This mostly happens in third and fourth, but I have done it in second and first while moving. At first I thought it was because I forgot how to drive a manual, but the frequency that it does this, and the fact that the shifter seems to stop make me doubt it. I can shift the car while it's not running, and feel the shifter click into gear consistently, in all gears.
The tranny is from a '93, with 15k miles on a rebuild (donor car threw a rod bearing). The shifter is the rod shifter from a '95, and the clutch is a brand new BeckArnley (has Valeo printed on the disk) for a '94 Tempo. Flywheel is also new. I put about 2.5 quarts of Valvoline ATF (non-synthetic) in before driving it. I filled it until fluid was coming out of the fill hole, so it should have plenty in there.
Hindsight being 20/20, I checked myself, and I did overtorque the pressure plate bolts to 35 ft-lbs. I was thinking that this might cause the clutch to never fully disengage, which would cause my grinding and why it would not engage until the engine speed had dropped a bit. I wanted to confirm that this screw up could be the culprit before I started dropping the subframe again. Sorry for the long post!:thankyou:
