Spec Stage 2 with Stock Pressure Plate?????
ilikepoultry
6th motor SHO
Pewaukee, WI
Doable?
I believe I broke a strap.......
Now I'm looking to get a new PP
would a stock pressure plate be okay with the Spec Stage II?
yzstud
< my kawi
Minnesnowta
should be fine.
what kind of pp do you think spec uses?
all pp's are made by valeo, its all the same
the only thing the aftermarket companies do(some of them) is reinforce the straps and powdercoat the pp
they are all the same
yes, a "stock" pp will be fine with a spec disc
zak
east of Hartford
The stock pressure plate offers you the same strap strength. SHOnut has a new clutch with upgraded straps . . . I think the OP is asking about a Spec stage II disc with stock pressure plate - . . zak
