Nos
SHO Dude
Southeast
A better answer is that our intake maniflids were never designed to hold a liquid, only air. With a wet system the fuel will fall out of suspension and puddle in the intake and lean the mixtures out among the cylinders. I know, I've got the burned exhaust valves to prove it.
FWIW, I still have my direct port manifold up for grabs. First one with 5 bones gets it.
Geek SHO
SHO Addict
Rohnert Park, CA
Five dollars? DEAL :)
I've had a lot of fun with my Zex kit. I don't know anything about the NOS kit, but the Zex can be installed in a couple hours, and seems to be really compatible with the SHO.
SHO_DOODmorrris
Owner & Fanatic
Alberta
how many bottles would it take to blow my 3.0 up? its had the 60k done and has 295 000 km's on it. gets oil changes every 5k with synthetic. just rough estimate please
SASHO91
Zoom Zoom
San Antonio,TX
I think the clutch might not like it after awhile though..... that is, if your'e still on the stocker.
With that said, I still plan on jetting my car for a 100shot as well.... :naughty: It's holding the 80 very well.
Brett
SHOs before HOs
Minnesnowta
How nice are you going into gears with the giggle gas?
SASHO91
Zoom Zoom
San Antonio,TX
Fairly nice. Once the clutch is pedal is back up, I slowly get back into WOT. Not exactly slow, but i'm not bangin' gears either.
I have a video of me running through the gears off the bottle. It's very close to how I run on the bottle. There's no need to really slam gears anymore. I mean, the car is not insanely fast, but it most deffinetly gets up and moves.
SHO_DOODmorrris
Owner & Fanatic
Alberta
that makes sence, i woudl rather save my clutch a little more, i have the larger clutch in it by dynopak or whatever the Oe equivalint is. ill prob go with a 100 but 75 may be a bit better to start off with.
-M
SHO_DOODmorrris
Owner & Fanatic
Alberta
will any other kits work? if not why does it have to be those 2 part numbers? just curious.
-M
SHO_DOODmorrris
Owner & Fanatic
Alberta
P.S http://www.holley.com/05120NOS.asp just saw that on the NOS site. it says for use on the 3 and 3.2l taurus SHO on the site and in the manual it says for a GM 2.8l or a ford 3.4l.....
Another Q what does everyone pay per LB for their Nitrous? anyone looked into their own fill station?
-M
SASHO91
Zoom Zoom
San Antonio,TX
-M
That's the same kit i'm running, and it's the same kit for the Mustang.
I filled the bottle last week.... @ $60. Allready got to fill it again.... :evilgrin:
SHO_DOODmorrris
Owner & Fanatic
Alberta
how many seconds (or minutes) will it last if it was on continuously? so anyone got an answer for why NOS is safer then the ZEX kit? or is it just opinions? thanks
-Mitch
SASHO91
Zoom Zoom
San Antonio,TX
That's just my opinion on what I have seen and read.
As far as nitrous consumption, it depends on the jetting you run, temp., bottle pressure, etc....
