my god this thing sucks to work on power steering
1990pasho
pa
Well I have a power steering pump leak so I thought i would try to fix it today.Anyways after taring everythin off I cant seem to locate were its leaking.I removed the low pressure hose and inspected it.No holes in line.Everything seems tight.Any suggestions?
Kens1992mtxSHO
The Commonwealth
Could be leaking in the rack. Did you check the reservoir? Could also be leaking from there.
itwonder
VA
Mine was leaking out of the shaft. I replaced the pump with a rebuilt unit. The high pressure hoses leak too. To get the HP hose fitting loose at the pump, I use a 18mm crows foot wrench with an extension running toward the front of the car to where there is clearance for a breaker bar; see photo. If removing the pump, the other hard bolt to get to is the mounting bolt on the back side. Under the car, you will notice there is a fairly open area just to the left of the exhaust manifold. Use a wobble or flex socket on the bolt with a long extension run across the back to the engine to where you can use that open space to get your ratchet or breaker bar in. Definitely replace the HP hose at the same time if you replace the pump.
Before you do anything else, take the CID sensor off and inspect inside the housing for oil. If you see any, the cam seal is leaking and that oil is running down on the PS pump making it look like there is a PS leak.
IMG 0258
IMG 0261
IMG 0263
1990pasho
pa
Thank you itwonder.Very good pics man.That pumps awlful to get to.I'm hoping it was a loose clamp.I put it all back together but didnt test drive it yet.
unaslim
Sold
Tampa, FL
I was able to do everything from the top, but I have a 94. Used a gear wrench on the back bolt.
Lcasho92
