245x40/17 tires on a SHO?
dmoo21
el oh el
St. Louis Park, MN
does anyone run a 245x40/17 tire on their gen 2? would it look weird? post a picture if you have one please.
i am looking for new auto x tires and want to see if these would even fit.
suspension i have koni/intrax that are cut one coil.
-Dan
sho_bc
Dragonboater
Vancouver, Canada
I think you're going to have to trim and/or roll your rear fenders (i believe that puts you into Street Prepared?) to fit 245s. how well it does or doesn't fit also depends on how wide your wheels are, and their offset, and the brand of tires - different brands have different widths. ex. my toyo 225s vs my falken 225s, the falkens are noticebly wider.
*edit* just saw that you have subframe connectors as well... I think that alone puts you into SP or SM, doesn't it? and the aluminum sfb should put you into one of those as well.
K-Dawg
Treasure Coast, FL
-Dan
You'll want at least an 8" wide wheel for the 245s.
shomesomesho
G-force addict
more rubber, more HP.....
Yep, having either ALSFB's or SFC's puts you in Street Modified.
I run 245-40/17's on 17x8's with 35mm offset on my Gen 1. I had to cut the inner fender lip off for them to fit. You might have to do the same thing for a Gen 2.
Also, you probably shouldn't run more positive than a 38 mm offset or else the tire will rub the rear strut (assuming you're going with 17x8's and 245's).
dmoo21
el oh el
St. Louis Park, MN
dang, my wheel is only 7 inch. I was hoping they would squeeze on there. There is a local guy selling some tires for a good price and i wanted to jump on it.
thanks for the insight guys. I guess i will stick with 225's
-Dan
NCTaurusSHO
Guest
Elizabeth City, NC
I am running 235-45-17 on mine
Specs:
Tires Calculated Overall Diameter = 25.3 Inches
Tires Section Width = 9.2 Inches
So a 245-40-17 is:
Tires Calculated OD = 24.7 Inches
Tires Section Width = 9.6 Inches
A little too wide. I am running 17x8 I think you will have to stick with the 225s also
here is a pic however
Ashley20side20Medium
i figured you can see how wide they are from this pic. these are the 235-45-17s
ashley
92sho16
b00sted
Liverpool, NY
245/45/17. I have intrax springs on tokico struts. The front springs have 1.5 coils cut out.
