2 tokico's on front, monroes on rear?
SHO SPD
SHO member #480
Naples, Florida
Would it be ok to run tokicos on the front and monroes on the rear with eibach springs? I dont really see what the harm would be. Or would it be better just to sell the tokicos and run monroes on all 4 corners?
SHO SPD
SHO member #480
Naples, Florida
Why? What would be the negative effects? People run Eibachs with monroes with no ill effects. Whats the problem with adding a variable rate up front, while standard in rear?
SolidState
No Mo SHO
Toronto, Ontario, Canada
the springs aren't the problem.
I ran moog/tokico on the front and OEM/GR2s on the rear for a couple months, and the pogo from the back was crazy. In high-speed evasive maneuvers, the back end was really really unsettle.
The car was really really unbalanced...front was tight, back was loose....
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Why not just get a set of monroes for the front? Last time I bought a set, they were $65 shipped to my door for the fronts.
38SHO
#1 Oil Abuser
North Palm Beach
i don't think it will make that much of a difference, IF both front and rear struts are brand new
however to be safe, you could sell the tokico's, pick up cheap struts.. and pocket some cash
SHO SPD
SHO member #480
Naples, Florida
I guess variable wasnt a good word choice. I was refering to the different damping that the tokico does.
AREA 91
Area 91
FWIW: I have Koni inserts on the front and Moog struts on the rear of my daily driver. Rides great but it does have stock springs.
Sho Amo
SmkTyresntDrugs
Olney, Md
haha.
just buy moog struts i heard theyr better than coil overs
just kidding:dig:
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
That's interesting. I thought only Monroe, and Gabriel made a quickstrut for the Taurus?
SinisterSHO
Rust free
630, IL
Realistically, if your just going to drive your car on the street. Theres probably nothing wrong with running two different sets of struts. The monroe's might wear out rather quick because of the increased spring rate on the springs, however.
crystizel
