Chris and I worked on the tune today and got the car to run VERY well. In fact, it's now using all of its resources and may need more! I'm maxing out my Lightning 80mm MAF and 48# injectors at 5400+ ft altitude
The temperature is pretty cold here (20F), so that help with powers, but the altitude is still losing quite a bit.
I had to tighten the belt a little as I have only been hitting 12 - 13 PSI at 8k RPM, but now it is hitting 15 PSI at 7,500 RPM.
I'll be moving in 6 months to most likely Nebraska or Texas and I'm definitely going to need to upgrade
I'll pick up a 90mm MAF and raise the fuel pressure on the injectors and see how well it does.
I guess it is time to get the car on the dyno.
The temperature is pretty cold here (20F), so that help with powers, but the altitude is still losing quite a bit. I had to tighten the belt a little as I have only been hitting 12 - 13 PSI at 8k RPM, but now it is hitting 15 PSI at 7,500 RPM.
