Berryman's B12
AREA 91
Area 91
Simply the best gum/carb cleaner ever. I love it.
edit: Also available at Wall Mart
Ishodu
I just picked some up down there last weekend. Its great stuff, you get your stuff clean fast but you just know its prolly taken all that time you saved in cleaning off of your life :)
Racer X
SHO Pilot, Retired
Connecticut
Quoted for truth! :thumb:
AREA 91
Area 91
It hasn't effected me. "Woah! WOAH! Big dogs landing on my face".:nut:
hawkeye18
Sorta cares
Norfolk, VA
Don't read the MSDS, whatever you do.
Can't be any worse than Navy issue two-step primer. The "Hazards" section of that thing is SIX PAGES LONG!
I swear to god, that stuff has a flash point of absolute zero, and will give you everything from lung cancer to gout to zits to a fat girlfriend.
Storm-Chaser
Shit Louis
We found last weekend that O'Reilly's brake cleaner doesn't do too bad either. It was just as effective as the Berrymann's on cleaning several things.
93nighthawk
Mitchell, SD
I will second the fact that Berryman's rocks when it comes to cleaning, especially EGR gummed up intakes and butterflies. I have tried several brake cleaners and none of them would touch the crud that B-12 would wipe off.
As for the hazzards, we are working with gas, oil, freon, antifreeze, ect all the time, all containing very bad stuff, if one thing doesn't **** you, another will, so enjoy the present! :):cool::thumb:
Jonny Cash
Good boy
Hollywood, FL
After vigorous hours of battling the fumes of Berrymans B12 in Freds shop, its safe to say this stuff works in many ways.
Phoenix
SHOHOLIC
QC , Canada
Very well said and extremely true. :thumb:
itwonder
VA
B12 and Supertech Carb Cleaner both seem to work about the same for me.
AREA 91
Area 91
Rick James quote "Live Your Life!!!!" We're all gonna die some day. I would be content dropping over dead cleaning a SHO intake.:angelnot:
jthod
Mr. Goodwrench
Lincoln, Nebraska
AWSOME stuff!! Just don't plan on lighting up a cig, or running a propane heater, or breathing normally, but it sure does blast that carbon away!!:thumb:
blue2ndgen
Mi
Brian, did you use the stuff in the can that you pour in the tank or did you take your intake apart and spray it down with the spray can?
I recently pulled the intake on my Buick to changed the intake manifold gasket,vc gasket, and pcv valve. I sprayed everything down with b-12 while I was in there. I still have an unstable idle though so I was thinking maybe the can would flush through and clean something I missed.
The spray can does work very well but goes very quick.
AREA 91
Area 91
I have done both. To make the berryman's last as long as possible, buy the non spray cans. You can moderate how quickly you use it.
AREA 91
Area 91
When I go to Wall Mart to buy it, I buy the entire stock!!! I'm sure the check out lady thinks i'm going home to huff it down. :oogle: Then she looks at my dirty hands/face/jeans/shirt/face.......and I must work on cars.:snicker:
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
brian one look and you can tell your a gearhead threw and threw :thumb:
