352Ford
Has anyone actually converted their V8 SHO to a manual transaxle?
From what I have read on the interweb the bellhousing is a duratec, so one of the manuals from a duratec cougar, contour, focus, etc. should fit, right?
Any issues with using the cougar, contour, etc. pilot bearings (i.e. crank is not machined for one), TO bearing or flywheel (different engine in-balance).
What are guys doing for transaxles that are making big power (400-600HP range) with sticky tires? I am assuming the bare minimum you are going to need some aftermarket parts other than just a limited slip diff to make it live for any considerable amount of time.
Anything else I am forgetting like input shaft length, input shaft centerline to crankshaft centerline issues?
Thanks!
Thanks!
