how much did you lower you sho
shoclown
shoclown
sacramento ca
Okay we just bought a set of the 0r52s that are on sale. i bought a set of 18 x7 with a 225 40 18 tire the overall height of tire and rim is the same as my origanil baskets with oem tires . How much has other shos been lowered without causing problems? in the front it sits about 3 or 4 inches formm tire,the rear looks about 1 or 2. I would like to get as low as possible but not cause car to bottom out. i would like it as stiff as possible also..
if you have lowered yours how much and what means.i am looking at replacing the springs but not spending big bucks. intrax and eibach both look around 2-250. i have heard about the moog hd and napa but what is recomended by the majority?
HoustinoJillian
name's JUSTIN
usa
a search will answer pretty much all of your questions. intrax/tokikos seem to be the best for performance, i have shoshop linears (no longer available).
AREA 91
Area 91
Koni adjustable struts with Ground Control Coil over's.
I can go so low, that I can't pull my jack out.:rofl:
PAracer
West Chester, PA
A little of my rear tires are tucked into the fender. The fronts are now lower than an Eibach or Intrax equipped car. I've got 225-50 tires on stock slicers. I would not go any lower. As it is, I have to pick and choose a racing line down the highway to avoid bumps.
Easy answer for you. Run a ground Control kit over a set of Koni inserts. Then order a set of springs as stiff as you like. I would expect to need to roll the rear fenders of a Gen I when using wider wheels like you have chosen.
justin mccluske
washington
i got kyb's and cut iboc's . im not sure how low my car is compard to stock but i can tell you it rides nice and there is no suspension noise .my rims are 18's with35 series tires.
ohfosho
ontario SHOwner
ontario, canada
lol! yes my car has springs that were chopped a bit by a previous owner... could be cargocoils... but my car is about an inch lower up front... stock rear sag equals it all out.
need to drive on 2x4's to get a jack under. they stay in the trunk... make sure you got some 4 ft 2x4s if your car ever needs to be flatbedded!
oh and i need to go up steeper drive ways angled... like it better that way anyway!
95greenmachine
95greenmachine
Huntersville, N.C.
shocontinental
you have any more pics, of the hood in particular, ive been lookin in to gettin a cowl hood and yours is the same color as mine
thanks, these look good guys
1993MTXSHO
Its a Taurus...
Jersey
Here's how much I lowered mine.
:biggrin:
ha, you car stock looks lower in the front then my car on its eibachs:rofl:
EDIT: unless that first pic isnt stock and if youre atx that explain it. My car mtx + lighter hood = sits higher up.
shoclown
shoclown
sacramento ca
What do you want for them? why dont you like them? is it just not the ride height you want? i think your car looks good...do you have eibachs and what did you do to them?
