High Quality Fog Lamps
MelectroK
Michigan
I was hoping someone with taste could help me out. I was in a recent accident with a deer and broken my driving lights. The insurance company will buy me new ones but I have to tell them what I want....FAST. I had on my car a set of Catz super white driving lights. Retailed at about 230 when they where new. I cant seem to find Catz lights anywhere anymore besides HID and dont think that will fly with the Insurance company. When I do searches you all seem to talk about some 30 to 50 dollar sets. No pun intendended but I feel that those wont measure up to what I origonally had. Does anyone here have any experence with some good quality lights that are durable and bright. Some that are properly focused and dont leak?
Thank you.
kzoosho
Holset HX52
grand rapids/kalamazoo
Thank you.
Go to pepboys and get a set of those pilots. fit right in and look damn good. You remember the ones that were on my green SHO? those are pilots.
MelectroK
Michigan
How much are those do you remember? I need to run it through the insurance company. Do you know what bulbs and wattage those are?
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
I have a set of those pilot fogs as well. Let me see if I can load up a couple of crappy pics I took with my cell phone.
whiteman_01
Well-Known Member
Hastings, MN
I have the Hella FF75's and i like them a lot. They are nice and bright out of the box, and thats with a 55 watt H7 bulb. I ran the silverstar 100 watt ones for a while, but i was replacing a bulb about once a month. That got to be too much money.
http://www.autoanything.com/lights/69A1330A0A0.aspx
I found a pic that shows them pretty well. Here you go
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
They're H3 bulbs, rated at 55 watts. Not the best out there, but a huge improvement over the stock fogs.
M01A0185
M01A0201
M01A0199
I'll try to get some better pictures tonight, as these were taken with my cell phone.
SASHO91
Zoom Zoom
San Antonio,TX
Here are my Projector's w/100watt H3 bulbs.
DSCF0263
DSCF0262
DSCF0270
I have since added a HD harness, and output is probably 50% better.
IIRC, I payed 30-ish for these...
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
Wow, the light output is incredible. Do you even need to use your headlights?
SASHO91
Zoom Zoom
San Antonio,TX
yes and no...
I live out in the country, so I use all the light that I have (all 290watts worth).
But for inner city driving, I *could* get away with just the driving lights.
The problem with that is, since the fogs are mounted so low to the ground, you can't really project down the road alot, without aiming them a bit high. Two problems with that part of the deal, is 1)you'll blind oncoming drivers and 2) you loose useable light that is being projected upwards...
But they do project down the road fairly well, and light up the road infront of the car 10x better than the stock setup.
I'll grab some pics while driving with them on tonight. :thumb:
baySHO_510
**** It broke!!
Manteca & Oakland Ca.
If your insureance company is going to pay for them get some sylvania xenarc x1010 HIDs. But if you're getting a check and buying them yourself then I would go with something like SASHO91. By the way SASHO what kind of projectors are they?
SASHO91
Zoom Zoom
San Antonio,TX
I can't recall the name of them, but I did post a link to them on eBay not too long ago... (can't find that thread either)
gimpysho
SNJ
Foglights
IMHO the best value is the Hella 20/20 Optilux runs about $54, $58 @ Summit, JC Whitney, Autobarn.com, and some Walmarts. These lights have a fog and driving ligt in both lights 4 555 watt beams total. the switch fits in stock dash opening. It's nice to switch from driving to fog mode. The fit stock location & oprning. Some modification of stock brackets requied (60 min job). Hella makes oem lights. I've been using the 20/20 for 1.5 year no problem.
Gimpy
SASHO91
Zoom Zoom
San Antonio,TX
Took some pics tonight of the lights with the harness. Just for a comparo....
Before the harness-
DSCF0263
DSCF0262
after the harness- (it's wet outside)
DSCF0670
DSCF0671
Just the fogs-
DSCF0673
With the headlights (low beam)-
DSCF0674
DSCF0675
NOTE: The driver side bulbs' low beam filament is not so good, and I believe that's why the output is less than the passenger side. Once I build a harness for the high beams, im going to throw in some 80/100watt bulbs in.
Anywho... thought i'd share those new pics.
MelectroK
Michigan
I am set on these, the insurance company gave me a set of Catz driving lights as a replacement.
