Any mechanics near?
hypnotic
Palm Bay, FL
I want to know if there is any mechanics that know how to work on these cars preferably in brevard county. I'm sick of it and I want someone else to look at it.
-Craig
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
hypnotic
Palm Bay, FL
Yes I am still having these problems. I need somebody to look at it. I was going to go to the junk yard today to try to get some things. If you would be willing to look at it for me that would be awesome. I just need to know when you are available.
-Craig
K-Dawg
Treasure Coast, FL
If Chris can't help you, I'm about 45 mins south and can help you out. You said you've replaced the TPS? Do you get a check engine light when you have these problems? Might want to check all the grounds and connections for the DIS. Did this start happening after replacing the plugs and wires?
hypnotic
Palm Bay, FL
I get the CEL only when the car is bucking, it doesnt stay on, just as its doing it. It started happening slowly after I replaced the plugs and wires, but I guess it was after I did them. I got the FM plugs from ford and I cant remember what wires but I was thinking of getting a new coil pack. Could this be an issue with bucking? I have checked all the grounds that I know of, like the strap from the intake to the firewall, and anyone that I could find. I cleaned and wire brushed them. Also its like the fuel cuts in and out. Thanks.
-Craig
Cocoa,Florida
there are two bolts that hold the crossover tube on the intake,the piece that this DIS is mounted to. make sure these two bolts are there and tight.
SuperchargedSHOguy
Got 1000 hp?!?
Caribbean
Sounds like it could be a couple different issues. If you can wait a few days I can give you a hand as I have a lot on my plate right now. If you need it fixed asap, let Kelvin or Brian assist you as they know as much if not more with these cars. I am not on here everyday and they normally are. You can normally trust anyone that posts in this section that lives in FL.
