Finally Upgrading After 18 Months Of Ownership
YamahaRick
The South, USA
I just ordered the Gearhead Kit as well as downpipes with cats from PPE. Found a nearby shop that will ceramic coat the pipes, as well as another good shop to do the install.
I have a dyno appointment tomorrow for a "before" run. I will also do an "after" run.
I've learned a lot from the forum, so thanks to all that contribute here.
YamahaRick
The South, USA
Received confirmation pipes and tune kit will both be here next Monday.
Had a baseline dyno run performed yesterday. Unsure how to interpret results in the graph provided, nor do I believe the numbers shown. My assumption was with a rating of 365HP at the crank wheel output would be quite a bit lower. The dyno was a Mustang brand.
My only concern is comparing before and after, so I am not worrying about it too much. I also had the guy send me a text file with raw numbers. Once I have it imported into Excel and formatted, I will post that.
1780585628544
1780585698122
1780585805901
Texas Marauder
Lone Star State
All I'm saying is that IF the engine is 365 HP net and IF the dyno 308 HP is correct, that works out to approx. 15% loss. Maybe neither is correct. It's all a numbers game.
YamahaRick
The South, USA
I finally looked at the text file of one of my dyno runs. The A:F ratio was a consistent 9.5. Is that what others here have seen? Are most stock tunes (amongst all gas vehicles) that conservative?
