Help pls! Scary noise from the front left side.
Mayfair
EU
Hey everyone!
I’m new around here, so apologies in advance if I dropped this in the wrong section.
I’ve been reading your threads since late 2021, right after I bought my Taurus, and I recognize a bunch of you by your avatars - but I’ve never actually posted before.
Guess the time has come, because honestly, I’ve got no clue where else to turn
I own a 2011 SHO. Bought it with 266,000 km (165k miles) on the clock. Since then, I’ve put about 56,000 km (35k miles) on it.
Let me first drop the full list of fluid changes in the transmission, PTU, and rear diff - all done by yours truly, so you know I’ve been keeping up with the maintenance.
=266,000 km
• Installed a used transmission (came off a 140k km car)
• Changed fluid — FoMoCo ATF
=280,359 km
• PTU fluid change — FoMoCo
• Rear diff fluid change — FoMoCo
=287,000 km
• Transmission fluid change — FoMoCo
=292,948 km
=317,000 km
• Flushed PTU 4 times in a row — FoMoCo
(I did it as a preventive measure, driving 5–10 km between each flush to wash out all the gunk from that hellhole of a unit.)
*** Bad times kicked in. That’s when the first weird noises and strange behavior started showing up — I’ll describe that in detail below. ***
=319,263 km
• Flushed PTU 5 times in a row — Liqui Moly
(1–5 km between each drain/refill)
=319,300 km
• PTU fluid changed twice in a row — Liqui Moly
• Rear diff fluid — FoMoCo
=321,500 km
=322,240 km
• PTU fluid change — Amsoil
So here’s the actual story (yeah, it’s a long one):
A few months back, right before summer, I hit the autobahn. At around 120–150 km/h, I suddenly felt a vibration shaking the whole damn car.
I thought - “Okay, maybe a wheel issue or driveshaft imbalance.” But I hadn’t touched anything recently, and it drove perfectly fine before that.
Later that day, during a hard launch, I felt what seemed like the front left wheel slipping. I figured - “whatever,” left side was on dirt, right on asphalt.
But… no TCS light, no dust cloud, nothing.
Got out - no tire mark on the ground.
Tried again. Same metallic clicking and ABS-like vibration under my feet - sounded like splines spinning inside a housing.
(I’ll attach a few videos later - same damn sound that’s haunting me again now. It’s the exact same one from back then.)
A few hours later I’m cruising the autobahn again, end up racing another car - hit 200+ km/h for about 20 minutes, steady pull, no issues at all.
No overheating, no leaks, nothing bad.
Only the usual smell - you know, that burnt chicken shit mixed with crude oil refinery aroma — the classic PTU perfume)))
Had that smell from day one. Thought it was road grime or exhaust residue.
Later learned on U.S. forums - nah, buddy, that’s just “normal SHO ownership.”
Fast forward to that same evening:
After a long 2-hour car wash (so fluids were warm but not hot), I fired it up, did a full-throttle launch - and bam, rear wheels didn’t spin.
Did it again - front wheels smoking, rear drive gone. Felt like I was driving a damn Civic with VTEC and a stick shift. Lots of wheelspin, lots of smoke
So, the next day I decided to drain the PTU fluid - expecting to find a surprise in there, like chunks of gears - and then go hunt for a new PTU
Since I’m in Germany, buying anything from FoMoCo fast is basically impossible. Nothing happens fast here, except cars on the autobahn. So I went with Liqui Moly. Never used it before, but I just wanted to quickly find out what’s wrong with the car.
I sucked that swamp out with a syringe - and saw nothing new. Same as always: horrible, stinky, dark gray sludge. The plug was clean, just a bit of metallic dust. Business as usual.
Mileage: 319,263 km.
I changed the PTU fluid five times in a row (driving 1–5 km between each change).
Could’ve kept going, but after the fifth round I was done. The smell of 75/140 was killing me, oil drops were raining from every part of the undercarriage, my head was itchy, my clothes ruined - I’d had enough.
There’s no drain plug at the bottom, so I always have to suck it out and refill through the side plug. It’s insanely hot around there - the cat, oil pan, and PTU - pure ****. My arm felt like a fried chicken.
Then I went for a test drive.
No sounds from the front left wheel, AWD works, car launches perfectly. Tested in different modes. Everything fixed itself - my favorite kind of repair
A few days later, nothing to do, two bottles of 75/140 were still sitting in the cupholders.
Mileage: 319,300 km - only 37 km after the last change.
Changed PTU fluid twice more (still Liqui Moly).
Also changed rear diff oil (FoMoCo).
Everything’s great, no noise, no problems. Using the car as usual.
Just to calm my soul, I did one more “shot into the void” - 2,200 km later.
Mileage: 321,500 km.
PTU oil change again (FoMoCo).
Fluid looked the same: smells like death, black, no visible metal bits or shavings.
The turn of events.
After a few months of carefree driving - suddenly I hear a hum.
Sounds exactly like a bad wheel bearing. Every day it gets louder.
Under acceleration - louder. Coasting - still there.
Bought a MOOG hub (couldn’t find anything else). Removed the old OEM one - 322,200 km on it. Spinning it by hand - yeah, slight bearing noise.
Put the car back together, feeling happy - rolled out of the garage… and the noise got way worse!
Now it’s a hard metallic vibration through the floor, the same sound I had months ago when the car first started acting up.
But! Now there’s no noise when I let off the gas - silent when coasting.
So yeah, the hub was part of the noise, but not the main problem.
Time to blame the driveshaft.
Of course, there’s no new half shaft available for sale. Ordering one from abroad costs a fortune, and I don’t want to gamble replacing a good part.
Out of curiosity, I tore the old one apart.
With that kind of noise and vibration, I expected to see a completely destroyed CV joint… but no. Looked fine.
There’s some wear on the inner cup, but minimal - you can’t even feel it with a finger. Well, 322,000 km after all.
Tripod bearings spin smooth, no noise. Cleaned everything and packed new grease.
IMG 2984IMG 2988IMG 2989IMG 2990IMG 2993IMG 2992
I couldn’t open the outer CV joint - didn’t have proper clamps.
That sucks, because I can’t be 100% sure it’s fine.
But the whole shaft has zero play, no knocking, no crap.
Ordered Amsoil 75/140 online. Wanted to check PTU fluid for metal shavings.
Replaced FoMoCo with Amsoil at 322,240 km.
The drained fluid smelled as usual - nasty, blackish-gray.
But for the first time, I poured it into a clean, clear bucket - and saw a bit of very fine, barely visible gray metallic dust. More like powder than shavings. (Got a video too.)
Filled it with Amsoil - problem didn’t change one bit. Same awful noise.
Before posting here, I tried hunting down similar sounds in videos about PTU or axle failures - even on other cars. Nothing matched.
Shops around here can’t help me. Mechanics don’t know American cars. Their “repair strategy” is just swapping random parts until something works.
Even though the Explorer V was officially sold in Europe and shares many parts with the Taurus SHO - the official dealer still can’t service my car. They can’t even find brake pads by VIN, let alone handle real repairs.
Please share your thoughts or experience - any guesses on what could be wrong.
Sorry for the wall of text - I just hope your comments lead me to the solution of this mess.
Thanks everyone, and good luck out there!
BradM
I didn't see your original post but I've read it now. With all due respect, you might want to try a different approach when posting to a car forum. 99% of what you posted wasn't needed. Be more concise and leave out the gratuitous stuff. And following up your post by trying shame the forum for not responding is not going to make things better.
SHOrod
Torrie Tuned
Cedar Rapids, IA
From looking over the post it sure seems like all indications would point to a bad PTU. The one in my car had dissolved a tapered bearing over time.
-Rod
Mayfair
EU
Damn, what r u on about? Which 99% were unnecessary?
Don’t cry, just move on))
Mayfair
EU
-Rod
Thx four your opinion. The car is over 10 years old, the platform has been used in several models, and I haven’t found any sounds like that online yet.
SHOrod
Torrie Tuned
Cedar Rapids, IA
The noise sounds consistent to me of a PTU issue, and you mentioned having to flush the PTU multiple times to get the gunk out. Some of that gunk is probably disintegrated tapered bearing or bearings. If you want to me more sure, you should find someone with a ChassisEar and place microphones on your PTU at the input side and the output to the rear driveshaft. I'd also suggest putting one on the rear driveshaft carrier bearing mount. Get the noise to happen (which seems easy for you to do) and see which microphone indicates the noise to be the loudest. This was the approach I took to determine my noise was from the PTU. I tried to deny it for a long time as well.
-Rod
SHO-moco
ct
Just spitballing but maybe the right front cv joint intermediate shaft or "inner shaft" It has a bearing in it, I have heard them make some crazy noises before. If you go under there to look at it also look at the clearance between it and the rear bank catalytic converter. I had my rear cat loosen a little from the turbo housing which allowed the cat assembly to shift just a tad. Caused my axle shaft and catalytic converter to make contact, could see the marks from the rubbing.
Tbird6
Hey a SHO in the EU! You must have a real unicorn!
What's puzzling about your problem is the PTU fluid is always black and is in terrible condition when you change it. Even after just a few thousand miles?
No mention of how much your pulling out and how much your putting in? The PTU only holds what I consider a microscopic amount of fluid for what is does. I mean 18 oz? That's all? You can't get it all out either so at best without a drain plug it's only a partial fluid change.
My 2014 MKS is at 115 K miles so WAY less than yours. But my experience with PTU fluid changes is much different than yours? Yes the first couple had a good bit of black sludge/paste type crap in it. BUT as the miles went on and I kept changing the PTU the fluid went more and more honey colored and the black tapered off and finally disappeared.
My last fluid change at 110K Miles (Again Way less than you!) I was very surprised to see the nice condition of the PTU fluid I pulled out.
My opinion is the damage was done long before you got the car. I am convinced that early and consistent fluid changes are the number one thing an owner can do to prolong the life of the car.
Normally the PTU smell is described as a Propane type odor. Also you probably know this but with the massive amount of miles and the number of times you changed the PTU fluid. I would strongly consider adding a drain plug. Now yes this should have been done by Ford to aid in maintenance. But hey at least they did put a drain plug AND a dip stick in for the transmission!
Take a look and after owing the car for 10+ years (It's been the most reliable and has had the least repairs of any car I have ever owned or knew about!). I wish I had added the PTU drain plug the first week I owned the car! I may still do it.
Installing PTU Drain Plug
He even went one step further and added a drain plug to the RDU as well!
The PTU is cooked. When it fails you will probably crack the trans case too. Changing fluids are only prolonging the death.
Here is a very good explanation by a member on here named Mr.HighCaliber.
"PTU's don't fail at least not from a power handling perspective. These only fail from lack of maintenance. Spun bearings and galling of the gears from lack of lubrication.
High Heat dries up the lighter oil molecules in the ****, which causes more heat due to lack of lubrication (thermal runaway) which leads to the remaining gear oil turning to thick black paste which clogs up the vent tube in the ptu which cause pressure buildup in the ptu which forces the remaining, non-congealed fluid out past the shaft seals. Now the only left is a thick paste thats easily flung off of the gears, sticking only to the case. After this chain of events, the bearings run dry and begin to fail, next are the gears. Tolerances widen or things begin to sieze. Bearing and gear noise are usually the first signs of mechanical failure.
But the PTU internals are stout. The weakest part of our powertrain is the RDU Atc coupler. (The electronic coupler in the rear differential). At least in terms of tq capacity and power handling."
Austin2013SHO
Las Vegas
Well if it makes u feel any better I have a PTU I put in 20k miles ago and now I have the hard vibrations when driving and humming like a fat lady at choir practice. The bearings in them suck. This will be my 3rd PTU I put in it. Bout car at 75k miles now at 133k. So I am the first to tell u the PTU is a very finicky part. I am designing a easier way to service my next one right now and talking with a parts manufacturer in china that I know from sema to see about getting a stout better built one with better bearings and easier way to drain and fill it. Also working on some concepts with Red Bull racing guys to help dissipate heat better. I’ll keep u posted. In the meantime this is something I found that seems to be useful. Better breather and can be used to fill PTU instead of the side drain hole BS.
Austin2013SHO
Las Vegas
