GH IC drain size
no help here, I looked for it too late when i installed mine, and I didnt see it. it supposed to be passenger side from other posts. good luck, will be watching your thread.
J persons
Natchitoches, LA
I was asking this question prior to actually receiving the IC. After getting it and thinking about it a little, I think the supplied Allen plug is sufficient. On most all the drain plugs that I have seen, the 'ears' are too long, which would require a larger hole to be cut below the IC for access. I did find one that had a thumb screw, but it also would require a larger hole to be cut for access.
hey @J persons can you post some picks for me, like I said I put mine in, and in the mix of issues as always you run into, I totally forgot to look for it and see where in the shrouding it is hiding. Can you let me know the exact side too, I believe its passenger, that was after install before bumper cover I was looking, and we moved on.
J persons
Natchitoches, LA
Here's a YouTube video that shows exactly where the hole goes. It's at 13:19
The drain appears to be a 1/8" NPT.
i will be terrified drilling a hole in the shrouding post install now... yeah I saw that video and because it was the end, i forgot to look sooner... teehee. You will have yours take some pics if you dont mind, would like to see it on todays design, in case there was any changes.
Matt at Gearhead said they won’t have any intercoolers until December at best. Are there alternatives?
nope all custom work. if that doesn't bother you basically any good IC vendor but you will be piecing piping cutting shrouding.
