Need Tips On How To Change PTU Fluid, Non-PP 2015 SHO
Jake0811
Macomb MI
Does anyone know how easy it would be to change the PTU fluid and any potential issues i may run into?? Also how long between intervals for fluid changes?? TIA!
SHOCALL
STL
My bro, use the search function.
There are many write ups on this procedure and various methods.
Much respect for tackling your fluids.
THE BIBLE so you can ask other questions that don't get shut down, @SM105K post below, however I gave you all the starters for knowing everything about the PTU.
Thread 'SM105K's Ownership/Performance/Maintenance Thread' https://shoforum.com/threads/sm105ks-ownership-performance-maintenance-thread.138235/
Tbird6
I will only add to consider installing a drain plug. I wish I had when I first got the car. Just makes servicing the PTU so MUCH easier!
Again another invaluable suggestion from this forum.
2013 MKS Eco 110K miles all original with many fluid changes!
Adding a plug is super easy.
Jake0811
Macomb MI
Good to note, thank you!
Tbird6
It is but I have changed the PTU oil enough times that it's just a routine now. Remove plug-Suck fluid out-Fill to overflowing-Install plug.
I have a lift so things like this are nice.
I have done it on ramps too but getting too old to crawl around on concrete on my back and knee's!
