Oil pressure switch change with Performance Pack (How to)
Zpak
Es Aich Oh!
The region, Indiana
Low oil pressure warning popped up so I gingerly drove the rest of the way home and started to investigate. Oil was only about a half quart low but I noticed the front of the engine was covered with a layer or oil, AC compressor, alternator… soaked. Know it’s rare for the pump itself to go out and still had plenty of oil so I looked for the oil pressure sensor (switch according to Ford). It and the plug was soaked and had a drip of oil on it.
Searched a couple vids for removal and couldn’t understand how they got to it so easily. I could barely get a finger on it and there was no chance of actually working a ratchet. Then realized, it’s easy with non PP but Performance Pack has the oil cooler completely blocking your access to it. So, it’s gotta go.
Started with draining all the oil and working with the oil filter still removed, it helps. Next I removed the heat shield on the exhaust manifold. That actually cleared up a bunch of room. Three 8mm’s and it’s free. Takes a bunch of maneuvering to actually get it out between the manifold, turbo, and fans but eventually found the right combination of twisting and pulling to squeeze it out. Then, removed the six 8mm bolts holding the oil cooler on. Got three from the bottom and three from the top. Two of which on top are by brail cause you just can’t see them. After it’s free since I had no interest in disconnecting the coolant lines to the cooler block I removed the upstream O2. After that, there is plenty of room to shove it out of the way.
IMG 5758
IMG 5760
Now we have access to the sensor. Got the plug off and with a short extension and universal got the 21mm deep well socket on and yanked it out. It was leaking oil into the plug, found it pooled in the connector.
IMG 5756IMG 5757
Cleaned the plug up, stabbed the new one in, reassembled everything in reverse and we’re back in action. Took it for a once around and so far so good.
FREAK_SHO
Wisconsin
That is the kind of stuff I eluded to in the other thread.
Sharing info and experience...
Thank you!
Good to see that was simple failure.
There is a problem with the MB C218 cam position censors on the 5.5 liter Bi Turbo Motors. Oil seaps through the sensors, travels up the connector and shorts out the ECU.
Fun times.
Zpak
Es Aich Oh!
The region, Indiana
Fun times.
That’s good to know. So if I’m hearing you correct, upfront cost still fails to save you from cars being cars.
dannyorona111
View attachment 91948View attachment 91949
Did it ever turn back on or did that fix the problem
