fcable
I am considering using the Gen III V8 in a 1948 Ford in a RWD application. Does anyone know of a automatic transmission that would bolt directly to this V8?
I think the bellhousing is same/similar to Duratec 25 motors. So maybe a miata type or ranger might bolt up. Have to reasearch heavily first. Those are the two points I would start. Is it identical or close enough to Duratec and then go from there.
You can shout out to the v8 mailing list and see if they have anything to help. there should be a mailgroup link on the v8sho website or contact ronporter on this forum via the message or 'conversation' function found at the envelope icon top right
Thanks. I'll do some continuing research. I just got to believe I'm not the first person to put the V8 SHO motor in a RWD vehicle. Thanks again.It is an iteration of the other ax auto transmissions of the time. I would check and see if the bolt pattern matches the similar contour svt block and if so then maybe a ranger might bolt up.
Also, the minivan aerostar (vulcan motor based) might bolt up. Maybe a slight modification is used.
If the contour block bolt pattern comparison holds then there should be versions of rwd custom conversions out there.
At least a few Ranger based rwd used for v6 SHO motors I think.
I found one company, Performance Adapters. They say can mate any transmission to any engine...$1250Maybe Lincoln LS, Jag when it was a ford product, and t-bird models had rwd and fuzzy memory duratec based blocks? Something to look at anyway. Lincoln might even have had a manual transmission option.
Take alot of digging to get a good answer. I remember pjtoledo posting a long time ago that a 2000-2002 Lincoln LS V6 Getgrag transmission may work with the SHO 3.4 V8. Maybe. Prrobably need a good measurement pattern and have to get a good hands on look-see.
Now adapters can be made to make mating up possible to many options. You just have to get creative with putting stuff together.
RWD SHO V8 in a Falcon
I thought that I could spice up the V8 forum that some have described as boring. I am in the process of putting an SHO V8 in a '62 Falcon in a rear wheel drive configuration. There was a lot of discussion about how to do this back when the cars were new but I have found no evidence that anyone...shoforum.com
V8 exterior dimensions and trans question
I'm thinking about swapping a sho v8 into my maserati biturbo. I need some exterior dimensions of the engine such as length, width, height, width of the oil plan/crankcase... Also, what rwd manual trans bolts up to the 3.4, if any? Any help is greatly appreciated.shoforum.com
RWD Conversion for Gen 3
I have a gen 3 98 SHO Which was given to my by my cousin. I have never heard of the SHO. Now that I have Zomg I love this car. I have gotten in deep to the sho world. I love working on and moding my sho. Now the sad part. I am in deep in the drifting world. My last car was a 240 sx with a...shoforum.com
Thanks for the info. I will continue to research.Duratec bellhousing?
I've read that the 3.4 shares the same bellhousing as the duratec motors. They put duratec 3.0s in rangers didn't they? I've also read that the lincoln ls(not the ls mkVIII or LSC) also shares this bellhousing pattern. I have a '97 parts car with a bad headgasket and I have an idea.... An...shoforum.com
