Thoughts?That would be the only thing I would double check with the wheels you're looking at, make sure they are load rated heavy enough for these cars
- WEIGHT
25.08 lb - LOAD CAPACITY
2100 lb
Do they report load capacity per wheel or per axle? Some companies do the latterThoughts?
- WEIGHT
25.08 lb- LOAD CAPACITY
2100 lb
Okay yah you'll be good with 2100 per wheel.View attachment 88029
From the FAQ's:
Velox forged wheels are at a minimum 2100lb load capacity with thicker rim and barrel sections to minimize deformation and enhance rigidity.
Yeah our tanks are like 4300+ lbs - so yeah I originally thought I was good until you picked out some vendors rate by axel.Okay yah you'll be good with 2100 per wheel.
I didn't know they were forged either. Mine are flow formed, but forged wheels are usually the strongestYeah our tanks are like 4300+ lbs - so yeah I originally thought I was good until you picked out some vendors rate by axel.
Yes - I saw how much they sell at Discount tire, nearly $700/per Costco is $300/per rim less - and the forge for the same as Niche Flow Form - same conclusion.I didn't know they were forged either. Mine are flow formed, but forged wheels are usually the strongest
Do you still have these rims I could take them off you/what rims are they so I can find them online! I like the american racing ones you have on now too but I think they are out of my price range right now!I don’t run staggered anymore but used to for about a year or so. Didn’t think it was really necessary so when I bought new wheels/tires I stopped doing it, never had any issue from it. Our cars aren’t AWD 100% of the time like Audi and Subaru. Used to be 20x9 all the way around 245/40/20 front and 275/35/20 rear with 1” spacers all around View attachment 88027
