Will 10.5 wide Wheels rub on Rear?(Stock Suspension)
ElTouros
Recently got a good deal on a set of Wheels.
(20×9) + 32
(20×10.5) + 15
But as you guys can see in the pics, the rear wheel is poking out the arch since it is a staggered setup.
I like the look of the wheels but I'm afraid I will be constantly rubbing in the rear upper fender with Stock Suspension. Bump... @yaycandy
I plan on keeping Stock Suspension for commodity so getting Coilovers is not something I want at the moment.
Any advice on this subject will be much muchh apreciated!
Is it possible that I can get away with this offset if the SHO Suspension is High enough or Stiff enough for me to keep these wide wheels without rubbing in the rear?
I could put some 275/40/20 tires if that will help it.
Thanks in advance!20230916 07565020230916 17074020230916 170732
SHO Slugger
Bay Area
I have 20x9 +35 fronts and 20x10.5 +43 offset with 275 40 20 on all four wheels. The rear setup rubbed but found the brake line bracket needed to be shaved down slightly. No more rubbing.
Schiv1010
