shogen4
Hi, this is Shogen4. My 2013 SHO has developed an oscillating engine RPM surge at idle. Fine at any load or speed however the engine sound a bit different under high acceleration. If I'm in gear, the car will surge forward a bit while the breaks are applied. When inside the car, it sounds like the radio is on low with a low base setting. Initially, i thought it was coming from another car.
The engine light has been on and checked. The dealer told me the timing chain id loose which has become a common problem for the SHO-V6 Twin Turbo.
Any thoughts?
Any thoughts?
