FullRace F150 oil cooler
Bluezone
Ont, Canada
I was looking up some EcoBoost info and came across this on YouTube.
Bluezone
Ont, Canada
I came across a Ford oil and filter application guide. One of the interesting things in it was the recommendations for oil weight on Road circuit used 2.3 l EcoBoost Mustangs. Apparently 5W50 is not 2 Heavy an oil for the cam phasers with track use on the 2.3 EcoBoost. Remember this is road course use!
Screenshot 20220203 200048 Adobe Acrobat
Here's the PDF this is from.
  • oil and crankcase applications chart_english.pdf
SHOthyme
MN
I would recommend the factory performance package oil cooler as it is designed for the transverse 3.5 ecoboost SHO engine. I am running one on my non PP SHO and it works great, for more information they can be ordered through my website.
How long did it take to install and was it basically plug and play?
Bluezone
Ont, Canada
So our oil pump can support an external cooler with no Issues?
It would depend a lot on the sizing of the cooler and lines.
Edit:
Also you don't want the oil pressure too high to compensate for any pressure drop across the cooler. That can cause other problems with oil driven systems, ex. VCT. That and most oil filters are in danger to burst the filter medium around 90 to 100 PSI iirc, could even activate the bypass valve in the filter. Short version, unfiltered engine oil.
Chuck Johnson
Columbus, OH
Edit:
Do you what would be the correct setup be for our engine? and if so could you post.
crystizel
