3.0/3.2 Build 250hp+ dyno tested engine.
FRANK FORD
Hawkesbury Ontario
so I'm looking to install or repower a 1988 ****** gt with a SHO engine so I'm looking to buy a already build engine with the bigger cams
and lots of go fast parts you know that engine you have wrapped up under your work bench and will probably never use even though its
a very good engine well I want that engine.
I need cheap but fast like a 3.2 with tri-flow cams with many more go fast parts N/A is what I need but I would take a turbo setup too.
I'm willing to drive 1000 miles from Montreal quebec or Ottawa Ontario.
tell me what you got.
Irish Pride
Irish Inside
MusicCityUSA
I have a freshly assembled high compression 3.3 that will exceed your HP requirements but I'm not within 1000 miles of Montreal and it won't be cheap. Currently wrapped up under my work bench.
93.5mm bore, 11.5:1 compression Wiseco pistons, ported/gasket matched heads, SHOnut +10 cams, NOS main bearings, NOS rod bearings, etc... Built it and then set it aside as something else presented itself.
-Chad
20190222 195743
20190222 195804
FRANK FORD
Hawkesbury Ontario
Thanks guyd found a engine , took compresion today and it was 210psi and all six cylinders thanks guys.
Yes engine is from a forum member on here. he has a nice ShoGun reproduction. top notch.
Irish Pride
Irish Inside
MusicCityUSA
Must be Jonathon Richard.
