Aww nuggets, I don't really have time to order anything good before inspection, nonetheless I would still like to know what it had.
1994 Service Manual:
SPECIFICATIONS: Brake Lining and Rotor Dimensions
Lining Material (OE): AK-NS171-HFF
Lining Material (service): JB-FA002-FF
Part No ***.xx 2018 - Shoe and Lining Assy
or 1993: Lining Material: B x D7800E ABEX 91646-Q B Non-SHO, Police
The exact answer of lining material above is useless to you. It is edge code from the lining manufacturer that the brake pad OEM gets their materials from.
You want to know more about friction material AK NS171H FF? It's made by Akebono Brake Industry Co, Ltd.
The JB FA FF brake material is Japan Brake Industrial Co, Ltd.
Ford put whatever the supplier had cheap in the car. Here you can see the same part # made in 2000 is different than made in 2003:
110303: Abex 60x1 (x=unreadable) EE LS pads (edge code EE identify the cold and hot coefficient of friction)
There's
new regulations on pads also, 2021 a requirement for lower copper and others, 2015 Washington state put a 3-leaf design, each colored leaf shows compliance level, etc.
Are you really going to put on the original plastic sway bar end links that freeze up and back out, when Ford has multiple service advisories and new part numbers to fix their problems? Just get new pads and be safe and healthy.
