Probably the most honest answer I've seen lol. However, I was wondering more in hp or et figuresA bill for a new transmission
Don't worry they soften up after a few hundred miles can become almost unnoticeable.Just got done installing the Anthony Dicunzolo Caitlyn Jenner mounts. They're a little harsh but definitely help the 2-3 shift in the 3 mile test spin I just took the car on.
Good to hear.Don't worry they soften up after a few hundred miles can become almost unnoticeable.
Hahahahahaha. It’s funny how things work in the end. The Jenner mounts will just continue to pay dividends as you build power.Just got done installing the Anthony Dicunzolo Caitlyn Jenner mounts. They're a little harsh but definitely help the 2-3 shift in the 3 mile test spin I just took the car on.
That is awesome! Thanks for posting!This site is so much easier, just click US Tracks at top, then scroll to your state and look for the track you are at. It gives you current DA, will give you forecast for upcoming DA and you can go back and look at any past day DA on each hour of day.
Air Density Online - Engine tuning weather
Real-time weather for racers including air density and density altitude. Over 1000 tracks and adding more every day.airdensityonline.com
490 whp on stock turbos? lololololololol Yeah sure ya did l.m.f.a.o. How much nitrous?My rear turbo blew on the dyno after a 490ish whp pull with a wastegate mod, stock turbos, no meth and 102 octane. Wastegate mod has been on for at least a year but i pushed it to far.
I wont push these turbos to much on hp. As its plenty of hp but it will increase the torque alot so im not sure how much the transmission will like it. But oh well. It goes i have a PP transmission sourced out already as id rather have the higher final drive
Thanks for this. Yeah that's a much easier site to use.This site is so much easier, just click US Tracks at top, then scroll to your state and look for the track you are at. It gives you current DA, will give you forecast for upcoming DA and you can go back and look at any past day DA on each hour of day.
It probably wouldn't hurt. Although you should let me test them for you to see if they work all right. LOLFinally after 4 months of waiting... Quick question, should I exhaust wrap these to maintain heat?
View attachment 81528View attachment 81529View attachment 81530
4 months wow! Congrats on the next step of your build mj...I hope mine come in soon too. Supposedly by the end of the monthFinally after 4 months of waiting... Quick question, should I exhaust wrap these to maintain heat?
Nice! That’s a big piece of the puzzle!Finally after 4 months of waiting... Quick question, should I exhaust wrap these to maintain heat?
if I could go back i would probably have the downpipes coated by Jet-Hot. I think the coatings are supposed to lower temps significantly.
