Speedometer not working/not shifting
40BelowSummer
Puerto Rico
Hey guys,
I just fixed my 2010 after a fender bender.
I recently changed the radiator/intercooler/battery/etc
Coolant sprayed all under the hood which I believe caused a few electrical issues.
I got most of them sorted after spraying the fusebox with electrical cleaner and it runs fine.
Now my only issue is the car won't shift out of 1st in D and won't shift past 2nd in M mode - the speedometer also isn't working. No codes. Any ideas or connectors I can check/clean. Is there a VSS?
Thanks!
40BelowSummer
Puerto Rico
The speedometer is based on the outputshaft speed sensor (OSS). No oss input to the pcm, no shifting no speedometer. Take a look at the transmission harness conector and harness itself.
Cleaned the harness connector and back in business! Thank you kind sir!
