Jordan_R
I have taken a moment to compile a list of components of basically everything you need for the short block here.. Hope this is of use to those who don't want to use a big box store for their short block and are fine playing parts runner!
I also got with Ortiz and got my own coupon code up for 6% off items on their website so that's added in here also. CODE: autoracing (reference to my youtube channel name)
With that being said all these costs are assuming you are NOT reusing your stock block. This isn't going to be organized super well but gets the idea across. The items from Ortiz are optioned basically for extreme duty on all sides of things except the rods which are the H beam rods.
ortizperformance.com
Rods $603.30
https://www.ortizperformance.com/product-page/manley-3-5l-3-7l-forged-4340-h-beam-connecting-rods
Pistons w/ rings -.5cc w/ extreme duty $987.34 (CSS recommends using oversized pistons and boring. I personally have oem size with a light hone to straight after css process, but either works)
https://www.ortizperformance.com/product-page/manley-forged-piston-set-of-6-3-5l-ecoboost
Main bearings - race 131.25
https://www.ortizperformance.com/pr...ring-set-2010-2019-ford-3-5l-ecoboost-3-7l-v6
Crank Bearings - race $149.10
Total $1,870.99
autoracing -6% discount code
$1,758.72
Tasca I didn't price match anywhere else so cross reference prices maybe. OEM parts have 2 year warranty pretty sure
SHO Block AT4Z-6010-K $746.65
https://www.tascaparts.com/oem-parts/ford-cylinder-block-at4z6010k
Raptor Crank (updated 3.5 ecoboost crank) JL3Z-6303-C $182.56
https://www.tascaparts.com/oem-parts/ford-crankshaft-assembly-jl3z6303c
16+ timing sprocket GT4Z-6306-A $36.74
https://www.tascaparts.com/oem-parts/ford-crankshaft-gear-gt4z6306a
16+ crank pulley kt4z-6312-a $28.88
https://www.tascaparts.com/oem-parts/ford-pulley-kt4z6312a
16+ Crank pulley bolt HL3Z-6A340-A $1.40
https://www.tascaparts.com/oem-parts/ford-crankshaft-pulley-bolt-hl3z6a340a
Total $996.23
CSS closed deck on new block https://www.cylindersupportsystem.com/ $895 + $300 deck + shipping both ways.
Total $1195 + shipping
SHORT BLOCK PARTS COSTS $3949.95
This is almost everything you need with the exception of main bolts. Originally I went with OEM bolts, then moved to ARP hardware. The choice is yours as I think the job will be accomplished with either. Trans is still the weak link. Take all this to a machine shop of your choice and have them bore/hone depending on piston size. Mains will also need checked. You'll want to balance the rotating assembly. Assume at the worst $1,000 in machine shop work. (My total machine shop cost was $720 for reference)
www.youtube.com/autoracingyt
Rods $603.30
Total $1,870.99
$1,758.72
Total $996.23
