longliveSHO
Hi guys, got a weird one for ya today...
I recently replaced my blower speed control module and forgot to do whatever dance afterward to prevent future HVAC problems. Currently reaping the consequences
Anyway: I seem to have two separate issues. 2011 SHO, non-pp, with MyFordTouch.
1) I can no longer select where the air goes, it stays on the face vents permanently. Scouring the forums here it looks like the actuator for that blend door has failed. Normally, I would pull the trigger and order the part, but i've noticed that the recirculate door magically stopped working at the same time. I still have independent temperature control, on both the driver and passenger side. Might something larger be amiss here or do these just fail this often?
2) My air conditioning will not shut off! Not a normal failure mode on most vehicles. Even if the button is not lit up, I get freezing cold air out of the vents. I can turn the temperature up and add heat, but that just seems like a waste.
I have tried resetting the HVAC module (pull fuse #15 under the dash, turn the car on for 30+ seconds, off, replace fuse, turn car back on) and until I mess with any settings the A/C will be off. As soon as I mess with the temperature or try (in vain) to direct the air somewhere else the A/C turns on and the air is cold.
I'm at a loss! Anyone seen something like this before? The issue with the blend doors happened first, which prompted me to reset the HVAC module. Since the first reset the A/C issue has been present. I'm starting to lean toward the failure of the HVAC module given the multiple failures at once.
Thanks!
Thanks!
